Allows all current WinDaq Acquisition parameters to become the default condition when WinDaq Acquisition opens.
Parameters from a previously recorded data acquisition session may be loaded into WinDaq Acquisition using the Open Reference File function.
When you have set up WinDaq Acquisition exactly the way you like, you can make this configuration the default, so every time you start WinDaq Acquisition, it always appears this way.
the File menu click on Save
Default Setup.
File Save Default Setup (ALT, F, D).
Virtually every WinDaq Acquisition data acquisition parameter is saved to determine the default condition: Enabled display format, sample rate, compression, channels enabled, etc.
Keystroke Example
Keystroke |
Comment |
ALT, F, D |
Save current screen design as default condition. |
