Differential channel numbers greater than 8 are not recognized as valid entries.
WinDaq Acquisition always sequentially samples from the lowest channel number specified to the highest, except that a digital input channel in column 9 of the first row that has channels enabled is sampled first to enable Options Remote Events and Options Remote Storage, but it is moved to the last strip to minimize its visibility by reassigning other channels with higher numbers or below it in the grid.
It is not necessary to specify a continuous channel number list. Any channel number may be skipped (i.e., a channel list of channels 2 and 4 is valid)
The number or type of channels enabled for acquisition cannot be changed after the RECORD mode has been activated.
