Preferences > Maximum Sample Rate
Maximum Sample Rate
Note: This feature is nonfunctional when used with serial port instrumentation. Maximum Sample Rate/Channel is set to "Auto" instruments. This setting can be tweaked in those instruments by clicking the Auto checkbox off. Please be aware that tweaking the setting is slightly different than other instruments in that it specifies a Sample Rate/Channel (as opposed to a Maximum Throughput Rate).
Specify maximum sample rate.
 In the Preferences sub-menu click on Maximum Sample Rate….
  Choose Edit Preferences Maximum Sample Rate… (ALT, E, P, M).
For the some insruments, this dialog contains an "Auto" checkbox, allowing the value to increase automatically for optimum anti-aliasing as the maximum number of enabled channels on any device is reduced, up to Edit Preferences Maximum USB Burst Rate divided by the maximum number of enabled channels.
Uncheck the Auto checkbox and enter the desired maximum sample rate per channel in the Maximum Sample Rate/Channel text box. Click the OK button or press the Enter key to close the dialog box.
Models
Maximum Sample Rate
DI-710, DI-715B, DI-718B, DI-718Bx
4.8kHz
DI-149, DI-155
10kHz
DI-148, DI-158
14.4kHz
DI-220, DI-221TC
40kHz
DI-200, DI-210, DI-722, DI-720-E (Rev A), DI-730-E (Rev A)
50kHz
DI-720-E (Rev B), DI-730 (all others)
150kHz
DI-2008
2kHz
DI-1110, DI-1120, DI-2108, DI-2108-P, DI-4108, DI-4208
160kHz
DI-720-USB
200kHz
DI-400, DI-500, DI-720-PP
250kHz
