This preference is on by default. If the preference is turned off, grids and channel annotations are displayed with all values as they are plotted, but a complete display of an annotation requires plotting a number of values equal to ten times the number of characters that the annotation contains (32 maximum).
It should be noted that this preference item is simply a “graphics adjuster” that only affects how the display looks on your screen. Data acquired to disk is independent of this function.
Enable/Disable Show Grids and Annotations Early.
on Show grids and annotations early.
Edit Preferences Open New File on Full (ALT, E, P, H) or press Alt + Y.
When the Show Grids and Annotations Early Preference is enabled, a check mark is displayed on the Edit Preferences submenu immediately preceding the Show Grids and Annotations Early command.
