Click
the Shift Waveform Down button in the Toolbox.
the Scaling menu click on Waveform Down 1 Pixel or Waveform
Down 10 Pixels. Waveform Down 1 Pixel moves the specified waveform
down a single pixel in the strip and Waveform Down 10 Pixels moves the
specified waveform down 10 pixels in the strip.
OR
Drag in the waveform strip area to draw a selection rectangle around a portion of the waveform. The size of the selection rectangle does not matter, it is merely used to represent the current horizontal position of the waveform on the screen. Then with the mouse pointer positioned inside the selection rectangle, drag the selection rectangle “down” to move the specified waveform down in the strip to the desired position (within the limits defined by the A/D converter).
Scaling Waveform Down 1 Pixel (ALT, C, O) or Scaling Waveform Down 10
Pixels (ALT, C, D). Scaling Waveform Down 1 Pixel moves the specified
waveform down a single pixel in the strip and Scaling Waveform Down 10
Pixels moves the specified waveform down 10 pixels in the strip.
Select the waveform using the left or right annotation margin. Hold the SHIFT key down. Click and drag the waveform up/down in the waveform window.
