Acquisition Triggering > Special Considerations
Changing the trigger conditions with the Acquisition Triggering dialog box also affects the Oscilloscope Mode trigger conditions, and vice versa, even though the modes trigger on different channels.
If the Remote Storage or Remote Events Options are selected, they are ignored in Triggered Mode.
The trigger level is saved as a digital A/D converter value, so the associated level in engineering units will change if the channel gain is changed or the channel is re-calibrated.
There are some restrictions to the amount of pre- and post-trigger data that can be acquired.
  1. For 200 Series parallel port instruments (i.e., DI-220, DI-222, and DI-221TC), the total number of pre- and post-trigger data points times the number of enabled channels must be an even number less than 8180.
(pre-trigger points + post-trigger points) × number of enabled channels = (even number < 8180)
  1. For plug-in board instruments, the total number of pre- and post-trigger data points times the number of enabled channels must be an even number less than the DMA input buffer size (which is read by choosing Sample Rate from the Edit menu).
(pre-trigger points + post-trigger points) × number of enabled channels = (even number < input buffer size)
  1. For other parallel port instruments, if your sample rate is less than the bandwidth (or maximum throughput) of your particular parallel port (i.e., 40,000 samples/second for standard ports, 80,000 samples/second for bidirectional ports, and 250,000 samples/second for EPP), you can acquire pre- and post-trigger data points based on the following formula:
(pre-trigger points + post-trigger points) × number of enabled channels ≤ 64000
  1. For other parallel port instruments, if your sample rate is greater than the bandwidth (or maximum throughput) of your particular parallel port (i.e., 40,000 samples/second for standard ports, 80,000 samples/second for bidirectional ports, and 250,000 samples/second for EPP), the total number of pre- and post-trigger data points times the number of enabled channels must be an even number less than 7500.
(pre-trigger points + post-trigger points) × number of enabled channels = (even number < 7500)
