Preferences > Exit on Full
Previous |
Exit on Full
When this preference is checked, WinDaq Acquisition will exit the application without prompting the user when the file fills up. This allows a time-scheduled batch file to restart acquisition for the next file without using the -A switch on the command line, allowing multiple devices to start recording at the same time after receiving messages from a master unit which has Broadcast Sync Messages enabled.
 In the Preferences sub-menu click on Exit on Full.
  Choose Edit Preferences Exit on Full (ALT, E, P, X).
When the Exit on Full Preference is enabled, a check mark is displayed on the Edit Preferences submenu immediately preceding the Exit on Full command.
