This option allows you to enable/disable (toggle) the display of channel annotation (see also Channel Annotation) in the waveform strip.
In the Options menu click on Channel Annotations.
Choose Options Channel Annotation (ALT, O, A).
When channel annotation is enabled, the waveform strip will display the specified channel’s annotation and a check mark will be displayed on the Options menu immediately preceding the Channel Annotations command.
