The Maximum Sample Rate of the DI-145 is fixed at 240 Hz and cannot be modified in WinDaq software (it is grayed out).
Specify maximum sample rate.
In the Preferences sub-menu click on Maximum Sample Rate….
Choose Edit Preferences Maximum Sample Rate… (ALT, E, P, M).
Models |
Maximum Sample Rate |
DI-710, DI-715B, DI-718B, DI-718Bx |
4.8kHz |
DI-149, DI-155 |
10kHz |
DI-148, DI-158 |
14.4kHz |
DI-220, DI-221TC |
40kHz |
DI-200, DI-210, DI-722, DI-720-E (Rev A), DI-730-E (Rev A) |
50kHz |
DI-720-E (Rev B), DI-730 (all others) |
150kHz |
DI-720-USB |
200kHz |
DI-400, DI-500, DI-720-PP |
250kHz |
