Default Conditions
Previous |
Default Conditions
Function
Allows all current WinDaq Acquisition parameters to become the default condition when WinDaq Acquisition opens.
Parameters from a previously recorded data acquisition session may be loaded into WinDaq Acquisition using the Open Reference File function.
Activating Procedure
When you have set up WinDaq Acquisition exactly the way you like, you can make this configuration the default, so every time you start WinDaq Acquisition, it always appears this way.
 In the File menu click on Save Default Setup.
  Choose File Save Default Setup (ALT, F, D).
Special Considerations
Virtually every WinDaq Acquisition data acquisition parameter is saved to determine the default condition: Enabled display format, sample rate, compression, channels enabled, etc.
Example
Keystroke Example
Keystroke
Comment
ALT, F, D
Save current screen design as default condition.
