The Maximum Sample Rate of the DI-145 is fixed at 240 Hz and cannot be modified in WinDaq software (it is grayed out).
Specify maximum sample rate.
on Maximum Sample Rate….
Edit Preferences Maximum Sample Rate… (ALT, E, P, M).
For the some insruments, this dialog contains an "Auto" checkbox, allowing the value to increase automatically for optimum anti-aliasing as the maximum number of enabled channels on any device is reduced, up to Edit Preferences Maximum USB Burst Rate divided by the maximum number of enabled channels.
Uncheck the Auto checkbox and enter the desired maximum sample rate per channel in the Maximum Sample Rate/Channel text box. Click the OK button or press the Enter key to close the dialog box.
Models |
Maximum Sample Rate |
DI-710, DI-715B, DI-718B, DI-718Bx |
4.8kHz |
DI-149, DI-155 |
10kHz |
DI-148, DI-158 |
14.4kHz |
DI-220, DI-221TC |
40kHz |
DI-200, DI-210, DI-722, DI-720-E (Rev A), DI-730-E (Rev A) |
50kHz |
DI-720-E (Rev B), DI-730 (all others) |
150kHz |
DI-2008 |
2kHz |
DI-1110, DI-1120, DI-2108, DI-2108-P, DI-4108, DI-4208 |
160kHz |
DI-720-USB |
200kHz |
DI-400, DI-500, DI-720-PP |
250kHz |
