WinDaq Unlock
WinDaq Unlock
The optional (extra-cost) WinDaq/Unlock code provides extra features not available in WinDaq/Lite Acquisition software. These capabilities are specific to your device. There is no trial version.
Note: Activation is not necessary if you purchased the Unlock Code when you purchased the instrument - it will already be unlocked. WinDaq Unlocked stickers will be on the bottom of the device as well as on the box the device shipped in.
For DI-1120, DI-4108, and DI-4208 instruments, the Unlock Code allows you to record more than four channels of data and also enables ChannelStretch™ allowing you to synchronize data from multiple instruments (unlock code required for each instrument). Learn more about ChannelStretch at https://www.dataq.com/data-acquisition/channel-stretch/. The DI-4718B Unlock code unlocks Stand-alone data logging as well as ChannelStretch.
 In the Help menu click on Unlock WinDaq.
Choose Help Unlock WinDaq (ALT, H, U).
Unlock WinDaq
To Unlock WinDaq:
1. Verify that the correct Serial # is displaying for your device.
2. Enter the Key given upon purchase of the software.
3. Click OK to activate.
A success dialog box will indicate WinDaq was successfully unlocked. Activation is written directly into the memory of the instrument.
For help contact Technical Support.
