When a waveform window has been enabled, the following operations may be performed. Also note that event marks must be enabled for display (in the Options menu click on Event Marks, by choosing Options Event Marks with ALT, O, V keystrokes, or by using the ALT+F8 accelerator key sequence) before the following operations can be performed.
When event marks are enabled for display, a check mark is displayed on the Options menu immediately preceding the Event Marks command. When event marks are disabled, the check mark is not displayed.
