the Edit menu click on Insert
Mark. This inserts a positive-going event
mark
on the enabled window’s waveform at the point of waveform-cursor intersection.
Repeating this action toggles the event mark from positive-going to negative-going.
Note that this procedure will work on any channel number except channel
1. Note also that the waveform must be uncompressed (waveform compression
must equal 1) to insert an event mark.
Edit Insert Mark (ALT, E,
I). This inserts a positive-going
event mark on the enabled window’s waveform at the point of waveform-cursor
intersection. Repeating this action toggles the event mark from positive-going
to negative-going. Note that this procedure will work on any channel number
except channel 1. Note also that the waveform must be uncompressed (waveform
compression must equal 1) to insert an event mark.
Note: To protect start and event marks inserted in WinDaq Acquisition Software, Edit > Insert Mark will not insert upward-going marks into Channel 1 or change the direction of existing marks. HiRes WWB will also not insert Channel 1 downward-going marks, used for event marks that are not starts. Edit > Delete Mark and Edit > Clear Marks to TM will not delete Channel 1 start or event marks. Advanced CODAS will not peak capture channel 1.
