This function allows you to conveniently scroll through, in a forward direction, all the consecutive channels you have enabled when they can’t be displayed on the monitor all at once. This function is most useful when many channels are enabled (such as with an EXP Series channel multiplexer or with DI-500 Series channel expanders) and the size of your monitor or the amount of screen space devoted to the WinDaq Waveform Browser window prevents you from seeing them all.
To display consecutive channels that are higher-numbered than the one at the bottom of your monitor:
the View menu click on Forward
Range.
View Forward Range (ALT, V, O).
For example, say you have 32 channels of data enabled for acquisition but for ease of viewing and to keep a high degree of detail, you want only 8 displayed at a time on your monitor. You can use the Forward Range command to conveniently scroll forward through the remaining channels of data. Just select Forward Range from the View menu (or use CTRL+↓ keystrokes). The next higher-numbered 8 channels will be displayed.
