Range of Channels > Function
Function
This feature consists of three separate functions that allow you to conveniently monitor and manipulate all the channels you have enabled when they can’t be displayed on the monitor all at once. These functions are most useful when many channels are enabled (such as with an EXP Series channel multiplexer or with DI-500 Series channel expanders) and the size of your monitor or the amount of screen space devoted to the WinDaq Waveform Browser window prevents you from seeing them all.
These functions are similar to the Variable Waveform Assignments function in that they allow you to assign any enabled ADC channel to a specific display window, however these functions differ by allowing you to assign or manipulate a block of channels. The Variable Waveform Assignments functions only allow one channel assignment at a time.
