Used to enable or disable the waveform display grid pattern.
the Options menu click on Grids. This enables the grid pattern
if it was disabled, or disables the grid pattern if it was enabled.
Options Grids (ALT, O,
G). This also enables the grid
pattern if disabled, or disables it if enabled.
When the grid pattern is turned on (or enabled), a check mark is displayed on the Options menu immediately preceding the Grids command. This check mark indicates that the grid pattern is enabled, even though it might not be immediately obvious on the screen (for example, it might be the same color as the background). When the grid pattern is turned off, the check mark is not displayed.
(Assumes that the grid pattern is initially disabled)
Keystroke |
Comment |
ALT+G |
ALT+G |
ALT+G |
Enable grid pattern. |
Etc. |
Etc. |
