Enable and View Channels
Enable Channels
DI-1100 Channel Selection Grid
The current status of all channels is displayed in this grid. The Channel Selection grid allows the user to enable and disable analog input channels. All channels are enabled/disabled with a left-click on the channel box. Analog Input channels show a checkmark when enabled.
View Channels
  Choose View Format Screen (ALT, V, F). In the Format Screen box, select User-specified format… using ­↑ or ↓ keystrokes. Press ENTER.
