Reference Materials > Device Drivers and Device IDs |
Windows Version | |||||||
Hardware | 95 | 98 | NT | ME | 2000 | XP, Vista | Vista, 7, 8, 10 |
All Serial Devices1 |
N/A | Same as XP | N/A |
It is not necessary to specify DeviceDriver for products using a physical COM port DeviceID = "COMnn DeviceName BaudRate"2 nn=COM port number3 |
DI-145, DI-148, DI-149, DI-155, DI-158, DI-245, DI-710, DI-715B, and DI-718B USB versions1 |
Only necessary with multiple devices DeviceID = "COMnn DeviceName BaudRate"2 nn=COM port number3 |
DI-220, DI-221, and DI-222 |
DeviceDriver = "DI22nNT.DLL" DeviceID = n n = LPT# |
DI-1100 |
N/A |
DeviceDriver = "DI30iNT.DLL" i = 07 DeviceID = "nnnnnnnn" nnnnnnnn = the first 8 hexadecimal characters of the device serial number |
DI-1110 |
N/A |
DeviceDriver = "DI31iNT.DLL" i = 07 DeviceID = "nnnnnnnn" nnnnnnnn = the first 8 hexadecimal characters of the device serial number |
DI-1120 |
N/A |
DeviceDriver = "DI33iNT.DLL" i = 07 DeviceID = "nnnnnnnn" nnnnnnnn = the first 8 hexadecimal characters of the device serial number |
DI-2008 |
N/A |
DeviceDriver = "DI35iNT.DLL" i = 07 DeviceID = "nnnnnnnn" nnnnnnnn = the first 8 hexadecimal characters of the device serial number |
DI-2108 |
N/A |
DeviceDriver = "DI32iNT.DLL" i = 07 DeviceID = "nnnnnnnn" nnnnnnnn = the first 8 hexadecimal characters of the device serial number |
DI-2108-P |
N/A |
DeviceDriver = "DI34iNT.DLL" i = 07 DeviceID = "nnnnnnnn" nnnnnnnn = the first eight hexadecimal characters of the device serial number |
DI-4108, DI-4208, DI-4718B, DI-4730 USB |
N/A |
DeviceDriver = "DI36iNT.DLL" i = 07 DeviceID = "nnnnnnnn" nnnnnnnn = the first 8 hexadecimal characters of the device serial number |
DI-4108, DI-4208, DI-4718B, DI-4730 Ethernet |
N/A |
DeviceDriver = "DI37iNT.DLL" i = 07 DeviceID = Pointer to IP address or multiple IP addresses separated by commas (first item could be preceded by an unsigned 32-bit PublicKey for a ChannelStretch group and comma). WinDaq Dashboard uses the 32-bit time value in seconds since 1970 as a key. |
DI-400, DI-401, and DI-410 |
DeviceDriver = "DI40nNT.DLL" DeviceID = n n=WinRT virtual device #4 |
DI-710, DI-715B, and DI-718B, and DI-718Bx Ethernet versions |
DeviceDriver = "DI6nnNT.DLL" nn =0 to 39 are reserved 40 to 69 for DI-710-E, DI-715B-E instruments 70-99 for DI-718B-E and DI-718Bx instruments5
DeviceID = IP address (example "192.168.1.0") or DeviceID = IP address:Port (for Remote Devices - example "192.168.1.0:10001") |
DI-720/730/740/760-EN |
DeviceDriver = "DI8nnNT.DLL" DeviceID = IP address (example "192.168.1.0") nn = the order of WinDaq/IP installation - look in c:\windows\tpdataq.ini |
DI-500/510/720/730/740/750/760-P |
DeviceDriver = "DI50nNT.DLL" DeviceID = n n = LPT# |
Same as other systems for 32-bit versions, but N/A for 64-bit systems. | |||||
DI-720/730/740/760-USB |
N/A |
Same as XP |
N/A |
DeviceDriver = "DI72nNT.DLL" n =DeviceID = USB ID of the device |
DI-700 |
N/A |
Same as XP |
N/A |
DeviceDriver = "DI70nNT.DLL" n = DeviceID = USB ID of the device |
1The DI-145, DI-148U, DI-149, DI-155, DI-158U/UP, DI-245, and DI-71x USB versions all use a virtual COM port. Some products use a virtual COM port even though they may have an alternate interface connection (like USB). Such products use the serial port device driver and ID. For a list of devices using a Virtual COM Port see Virtual COM Ports.
2DeviceName = Model number of the device. BaudRate = the baud rate. For a listing of baud rates see Baud Rate. For Example: For a DI-158U installed at COM 2 with 38400 Baud the DeviceID = "COM2 158 38400"; a DI-145 installed at COM 8 would be: "COM8 145 4800".
3As specified during installation of the device. COM port numbers of 01 to 99 are supported. Example: For a Serial device installed to COM 1 the DeviceDriver=DI101NT.DLL. Go to Virtual COM Ports for instructions on finding the correct COM port.
4Virtual Device # can be found in c:\Windows\tpdataq.ini, or at the end of the WinDaq installation.
5The order of WinDaq/IP installation - look in title bar of WinDaq Acquisition when running device or check your installation directory for file(s) named WDQDK6nn.EXE.
6Starting WinDaq acquisition with V3.89 or later sets DLLName= and DeviceID= in the TPDATAQ.INI [Global] section, which become the default DeviceDriver and DeviceID if not set by a program using WinDaq.ocx or DataqSdk.ocx.
7Or other digit if using multiple unsynchronized devices or synchronized groups.
