Reference Materials > Gain Factors and Settings |
All products with programmable gain and PGL/PGH settings (if applicable).
DI-155
WinDaq Acquisition Gain Setting |
Gain Index |
Range |
1 |
0 |
+/-50V |
2 |
1 |
+/-25V |
4 |
2 |
+/-12.5V |
5 |
3 |
+/-10V |
8 |
4 |
+/-6.25V |
10 |
5 |
+/-5V |
16 |
6 |
+/-3.125V |
20 |
7 |
+/-2.5V |
DI-149 and DI-155 Rate channel 9
Gain Index |
Range |
2 |
1 |
0-10 kHz |
4 |
2 |
0-5 kHz |
10 |
3 |
0-2 kHz |
20 |
4 |
0-1 kHz |
40 |
5 |
0-500 Hz |
100 |
6 |
0-200 Hz |
200 |
7 |
0-100 Hz |
400 |
8 |
0-50 Hz |
1000 |
9 |
0-20 Hz |
2000 |
10 |
0-10 Hz |
4000 |
11 |
0-5 Hz |
DI-1120 and DI-4208
Gain Index |
Range |
1 |
0 |
+/-100V |
2 |
1 |
+/-50V |
5 |
2 |
+/-20V |
10 |
3 |
+/-10V |
20 |
4 |
+/-5V |
50 |
5 |
+/-2V |
DI-4108
Gain Index |
Range |
1 |
0 |
+/-10V |
2 |
1 |
+/-5V |
5 |
2 |
+/-2V |
10 |
3 |
+/-1V |
20 |
4 |
+/-0.5V |
50 |
5 |
+/-0.2V |
DI-2108-P
Gain Index |
Range |
1 |
0 |
+/-10V |
2 |
1 |
+/-5V |
4 |
2 |
+/-2.5V |
For gain indices 0 and 1, adding 1000 to ADChannelList channel numbers can specify a unipolar channel with min range 0V.
DI-1110, DI-1120, DI-2008, DI-2108, DI-2108-P, DI-4108, and DI-4208 Rate channel 9
Gain Index |
Range |
2 |
1 |
0-50 kHz |
5 |
2 |
0-20 kHz |
10 |
3 |
0-10 kHz |
20 |
4 |
0-5 kHz |
50 |
5 |
0-2 kHz |
100 |
6 |
0-1 kHz |
200 |
7 |
0-500 Hz |
500 |
8 |
0-200 Hz |
1000 |
9 |
0-100 Hz |
2000 |
10 |
0-50 Hz |
5000 |
11 |
0-20 Hz |
10000 |
12 |
0-10 Hz |
For rate channel 9 in any of the above devices, the upper byte of the ADDiffList table entry specifies a moving-window filter length for rate computation, from 0 for noisy and responsive to 63 for smooth and delayed (resulting in filter lengths 1 through 64).
DI-245 and DI-2008
Voltage
Gain Index |
Range |
1 |
8 |
+/-50V |
2 |
9 |
+/-25V |
5 |
10 |
+/-10V |
10 |
11 |
+/-5V |
20 |
12 |
+/-2.5V |
50 |
13 |
+/-1V |
100 |
0 |
+/-0.5V |
200 |
1 |
+/-0.25V |
500 |
2 |
+/-0.1V |
1000 |
3 |
+/-0.05V |
2000 |
4 |
+/-0.025V |
5000 |
5 |
+/-0.01V |
WinDaq Acquisition Thermocouple Setting |
Index |
Range (°C) |
B |
0 |
250 to 1820 |
E |
1 |
-200 to 1000 |
J |
2 |
-210 to 1200 |
K |
3 |
-200 to 1372 |
N |
4 |
-200 to 1300 |
R |
5 |
-50 to 1768 |
S |
6 |
-50 to 1768 |
T |
7 |
-200 to 400 |
DI-158U, DI-410, DI-500, DI-510, DI-715B, DI-720, DI-722, DI-725, DI-740, DI-750, DI-760
Gain Index |
Range |
1 |
0 |
+/-10V |
2 |
1 |
+/-5V |
4 |
2 |
+/-2.5V |
8 |
3 |
+/-1.25V |
DI-158UP
Gain Index |
Range |
1 |
0 |
+/-64V |
2 |
1 |
+/-32V |
4 |
2 |
+/-16V |
8 |
3 |
+/-8V |
16 |
4 |
+/-4V |
32 |
5 |
+/-2V |
64 |
6 |
+/-1V |
128 |
7 |
+/-0.5V |
256 |
8 |
+/-0.25V |
512 |
9 |
+/-0.125V |
DI-200, DI-222, DI-700, DI-710
Range |
PGL |
PGH |
Gain Index |
PGL |
PGH |
1 |
1 |
0 |
+/-10V |
+/-10V |
10 |
2 |
1 |
+/-1V |
+/-5V |
100 |
4 |
2 |
+/-100mV |
+/-2.5V |
1000 |
8 |
3 |
+/-10mV |
+/-1.25V |
DI-201, DI-220
Range |
PGL |
PGH |
Gain Index |
PGL |
PGH |
1 |
1 |
0 |
+/-5V |
+/-5V |
10 |
2 |
1 |
+/-0.5V |
+/-2.5V |
100 |
4 |
2 |
+/-0.05V |
+/-1.25V |
1000 |
8 |
3 |
+/-0.005V |
+/-0.625V |
DI-400
Range |
PGL |
PGH |
Gain Index |
PGL |
PGH |
1 |
1 |
0 |
+/-10V |
+/-10V |
10 |
2 |
1 |
+/-1V |
+/-5V |
100 |
4 |
2 |
+/-100mV |
+/-2.5V |
N/A |
8 |
3 |
N/A |
+/-1.25V |
DI-722 Amplified, DI-725E
Gain Index |
Range |
1 |
0 |
+/-20V |
2 |
1 |
+/-10V |
4 |
2 |
+/-5V |
8 |
3 |
+/-2.5V |
DI-730 and DI-4730
Gain Index |
Range |
1 |
4 |
+/-1000V |
10 |
5 |
+/-100V |
100 |
0 |
+/-10V |
1000 |
1 |
+/-1V |
10000 |
2 |
+/-100mV |
100000 |
3 |
+/-10mV |
DI-500, DI-510 High Voltage
Gain Index |
Range |
1 |
0 |
+/-1000V |
2 |
1 |
+/-500V |
4 |
2 |
+/-250V |
8 |
3 |
+/-125V |
DI-5001 (jumper selectable)
Range |
jumper +/-5 |
jumper +/-10 |
Gain Index |
jumper +/-5 |
jumper +/-10 |
1 |
1 |
0 |
+/-5V |
+/-10V |
2 |
2 |
1 |
+/-2.5V |
+/-5V |
4 |
4 |
2 |
+/-1.25V |
+/-2.5V |
8 |
8 |
3 |
+/-0.625V |
+/-1.25V |
