Reference Materials > How to Extract Information from a Variant |
The Variant information returned by the Active X controls is not always easy to work with. We can extract certain information from the variant. When the Active X control gets data from a hardware device it places each sample into an array such as the following: A(0) = sample1; A(1)=sample2; A(2)=sample3; and so on. When there are multiple channels the software stores them in order according to the channel list. If there are three channels it would store them as follows: A(0)=sample1 from the first channel; A(1)=sample1 from the second channel; A(2)=sample1 from the third channel; A(3)=sample2 from the first channel; and so on. Note the following program in Visual Basic:
Dim V As Variant
Private Sub DataqSdk1_ NewData(ByVal Count As Integer)
'the data will be returned to V as a Variant
V = DataqSdk1. GetData
'cn = number of channels minus 1
cn = UBound(V, 1)
'pts = number of data points minus 1
pts = UBound(V, 2)
'create an array to accept channel 1 data
ReDim Channel1(0, 0 To pts) As Integer
For i = 0 To pts
Channel1(0, i) = V(0, i)
Next
'plot channel 1
DQChart1. Chart (Channel1)
'plot all channels
DQChart2. Chart (V)
End Sub
Private Sub Start_Click()
DataqSdk1. ADChannelCount = 2
DataqSdk1. EventPoint = 10
DataqSdk1. Start
End Sub
Private Sub Stop_Click()
DataqSdk1. Stop
End Sub
Using and extracting information from a variant is slightly different in VB.NET. Consult your program's help files for more information regarding variants. Use the following example as a guideline to get you started.
To access the data returned by GetData, instead of using a variant, declare it as a "short" directly. Note the following example:
Public Class Form1
Inherits System.Windows.Forms.Form
Dim v(,) As Short
#Region " Windows Form Designer generated code "
#End Region
Private Sub AxDataqSdk1_NewData(ByVal sender As Object, ByVal e As AxDATAQSDKLib._DDataqSdkEvents_NewDataEvent) Handles AxDataSdk1.NewData
v = AxDataSdk1.GetData()
' the data can be accessed as v(chn, pt),
' where chn=0 for the first channel,
' pt =0 for the first pts
End Sub
