Enable Channels
Enable Channels
Enable Channels
DI-4108 and DI-4208 Channel Selection Grid
The current enabled status of all connected device channels is displayed in this grid. The Channel Selection grid allows the user to enable and disable all input channels. All channels are enabled/disabled with a left-click on the channel box. Analog Input channels show a checkmark when enabled. The general-purpose digital channel (channel 9) displays an "I" when enabled. The Rate channel (channel 10) displays an "R" when enabled. The Count channel (channel 11) displays a "C" when enabled.
View Channels
  Choose View Format Screen (ALT, V, F). In the Format Screen box, select User-specified format… using ­↑ or ↓ keystrokes. Press ENTER.
