Change the acquisition method of each channel or reset engineering units.
In the Edit menu, click on Channel Settings....
OR
Press F10.
This displays the Channel Settings Dialog Box.
Choose the desired Acquisition Method for the selected channel.
Filter
Default method. The DI-1120 employs a low-pass filter per analog channel with automatic corner frequency selection. The filter is a CIC (cascaded integrator comb) type that uses as many as 512 samples per channel to calculate in real time as data is acquired. Filter response is optimized when sampling frequency is set to ten times the highest frequency of interest.
Last Point
Maximum
Minimum
RMS and Frequency
RMS and Frequency are not supported acquisition methods in the DI-1120.
Use the Next and Previous buttons to scroll through enabled channels.
