Preferences > Reset Count on New File Record
Note: This feature is for DI-149 and DI-155 Counter channels (DI3) only.
The Reset Count on New File Record preference allows you to reset the counts in Channel 11 (DI3) of DI-149 and DI-155 instruments back to zero every time you record to a new file with the Edit > Preferences > Record Next File on Full feature enabled.
The counter channel accumulates counts over time whether recording or in standby mode as soon as the Counter channel is enabled. The accumulated values will be recorded to your data file unless you reset the counts to zero. The maximum count value is 16383 before the counter resets to zero automatically.
Use the Edit > Preferences > Reset Count on Manual Record in WINDAQ Acquisition software to reset counts to zero every time you begin recording a data file using the File > Record command (F4).
 In the Preferences sub-menu click on Reset Count on New File Record.
  Choose Edit Preferences Reset Count on New File Record (ALT, E, P, N).
When Reset Count on New File Record is enabled, a check mark is displayed on the Edit Preferences submenu immediately preceding the Reset Count on New File Record command.
