Preferences > Reset Count on Manual Record
Note:This feature is for DI-149 and DI-155 Counter channels (DI3) only.
The Reset Count on Manual Record preference allows you to reset the counts in Channel 11 (DI3) of DI-149 and DI-155 instruments back to zero any time you begin recording using the File > Record command (F4).
The counter channel accumulates counts over time whether recording or in standby mode as soon as the Counter channel is enabled. The accumulated values will be recorded to your data file unless you reset the counts to zero. The maximum count value is 16383 before the counter resets to zero automatically.
Use the Edit > Preferences > Reset Count on New File Record in WINDAQ Acquisition software when using the Edit > Preferences > Record Next File on Full or Open Next File on Full feature to reset counts to zero every time a new file is started.
 In the Preferences sub-menu click on Reset Count on Manual Record.
  Choose Edit Preferences Reset Count on Manual Record (ALT, E, P, T).
When Reset Count on Manual Record is enabled, a check mark is displayed on the Edit Preferences submenu immediately preceding the Reset Count on Manual Record command.
