Preferences > Brighten Selected LED
Allows you to enable/disable the LED to change color when a channel is selected or enabled. This allows you to easily determine which device has that channel.
 In the Preferences sub-menu click on Brighten Selected LED.
  Choose Edit Preferences Brighten Selected LED (ALT, E, P, B).
When the Brighten Selected LED Preference is enabled, a check mark is displayed on the Edit Preferences submenu immediately preceding the Brighten Selected LED command.
Please Note: The DI-1110 and DI-2108 do not support multiple synched devices. Multiple devices may be connected to your PC and display in the channel selection grid but only one device may have enabled channels. All other devices must have all channels disabled.
