Note:This feature is for DI-149, DI-155, DI-2008, DI-2108, DI-4108, and DI-4208 Counter channels only.
The Reset Count on Manual Record preference allows you to reset the counts in Channel 11 of DI-149, DI-155, and DI-2108 instruments back to zero any time you begin recording using the File > Record command (F4).
Use the Edit > Preferences > Reset Count on New File Record in WINDAQ Acquisition software when using the Edit > Preferences > Record Next File on Full or Open Next File on Full feature to reset counts to zero every time a new file is started.
In the Preferences sub-menu click on Reset Count on Manual Record.
Choose Edit Preferences Reset Count on Manual Record (ALT, E, P, T).
When Reset Count on Manual Record is enabled, a check mark is displayed on the Edit Preferences submenu immediately preceding the Reset Count on Manual Record command.
