the Scaling menu click on Grow. This expands the specified waveform
two times its original size in the amplitude direction.
OR
Point
to the right or left annotation margin and click the left mouse button.
This also expands the specified waveform two times its original size in
OR
Drag
in the waveform strip area to draw a selection rectangle. The selection
rectangle is used to expand or contract the waveform to a specific size
in the amplitude direction (within the limits defined by the A/D converter).
The top and bottom edges (or the “vertical limits”) of the selection rectangle
will dictate the amount of waveform expansion/contraction. Click the left
mouse button in the right or left annotation margin. The waveform will
be expanded to full strip size with the “vertical selection rectangle
limits” now defining the ±full scale values for the waveform. See also
Drawing
a Selection Rectangle and the Scaling
a Waveform Demo.
Scaling Grow (ALT, C,
G). This expands the specified
waveform two times its original size in the amplitude direction.
