the Scaling menu click on Waveform Up 1 Pixel or Waveform
Up 10 Pixels. Waveform Up 1 Pixel moves the specified waveform
up a single pixel in the strip and Waveform Up 10 Pixels moves the specified
waveform up 10 pixels in the strip.
OR
Drag
in the waveform strip area to draw a selection rectangle around a portion
of the waveform. The size of the selection rectangle does not matter,
it is merely used to represent the current horizontal position of the
waveform on the screen. With the mouse pointer positioned inside the selection
rectangle, drag the selection rectangle “up” to move the specified waveform
up in the strip to the desired position (within the limits defined by
the A/D converter). See also Drawing
a Selection Rectangle and the Offsetting
a Waveform Demo.
Scaling Waveform Up 1 Pixel or Scaling Waveform Up 10 Pixels (ALT,
C, P,
or ALT, C,
U, respectively). Waveform Up
1 Pixel moves the specified waveform up a single pixel in the strip and
Waveform Up 10 Pixels moves the specified waveform up 10 pixels in the
strip.
