When enabled, this function will display the Time-To-Beginning-Of-File (TBF) format or one of the other three time marker-related data formats in the left end of the bottom annotation line (live display field). When this function is enabled and the waveform is panned across the screen (or the cursor is moved), this display field is constantly updated to provide a “live” readout.
the Options menu click on Enable Live Display. This enables the
live display field in the bottom annotation line if it is disabled, or
disables it if enabled.
Options Enable Live Display (ALT,
O, N).
This also enables the live display field if disabled, or disables it if
enabled.
When the live display field is enabled, a check mark is displayed on the Options menu immediately preceding the Enable Live Display command. When the live display field is disabled, the check mark is not displayed.
When the live display field is enabled, the data displayed in this field is determined by the Select Live Display command setting. Refer to the Select Live Display function for more details.
When the live display field is disabled, off is displayed in the field with the last selected format.
Keystroke |
Comments |
F3 |
Enable live display annotation. |
F3 |
Disable live display annotation. |
