This format annotates the time difference from the time marker position and the cursor position in seconds. To display time from marker in the marker display field:
the Options menu click on Select Marker Display. This displays
a cascading pull-down menu containing the different marker display formats.
Click on Time from Marker.
Options Select Marker Display (ALT,
O, K).
Press ENTER. This displays a cascading pull-down menu containing the different
data formats. Use the ↑ and ↓ cursor control keys to highlight
Time from Marker. Press ENTER.
When the Time from Marker format is selected, the marker display field will show XXXX SEC(TM), where XXXX is the time difference from the cursor to the time marker in seconds.
