This option allows you to enable/disable the display of data or baseline values in the left/right annotation margin. If neither limit & frequency display nor acquisition assignments are enabled, the engineering units will toggle on and off along with the baseline value. To enable the Data Display (if disabled, or disable it if enabled):
the Options menu click on Data Display.
Options Data Display (ALT, O, D).
When the data display option is enabled a check mark will be displayed on the Options menu immediately preceding the Data Display command.
Note that the display annotation options can be enabled in virtually any combination to provide the desired result. However, in some instances one annotation option will override another.
