Introducing the All-new EL-USB-TP-LCD Single-channel Thermistor Data Logger
DATAQ Instruments is happy to introduce the all-new EL-USB-TP-LCD, a single–channel thermistor data logger. With a -40 to +125°C (-40 to +257°F) measurement range, the included 1-meter thermistor probe has an accuracy of ±0.1°C (±0.2°F). Capable of storing up 32,510 readings, with sample intervals ranging from 1 second to 12 hours, the EL-USB-TP-LCD can acquire temperature data, unattended, for months, or even years. Programmable alarms allow you to illuminate a LED when temperatures rise above or fall below user-defined levels, and a high-contrast LCD display allows you to view the current temperature, the maximum logged temperature or the minimum logged temperature.
The included EasyLog USB software gives you the ability to configure the EL-USB-TP-LCD (choose a sample interval, set alarm levels, etc), download and display (graph) acquired data, or save data in Microsoft Excel format.
For more information, or to place an order, check out the EL-USB-TP-LCD webpage at:
https://www.dataq.com/products/hardware/el-usb-data-loggers/el-usb-tp-lcd-data-logger.html
 Categories: Data Logger, New Products, Temperature Data Loggers
 Tags:
