The latest version of the WinDaq Dashboard includes two helpful new features to the Stand-alone data recording functionality of the DI-2108, DI-2108-P, and DI-4000 Series of data acquisition and data logger products.
Record on Power Startup
Use the Record on Power Startup checkbox in the Stand Alone Setup window to begin a recording session to the USB flash drive upon power-up.
![](https://www.dataq.com/blog/wp-content/uploads/2020/11/record-power-startup.png)
Usage is simple:
- Setup your Stand Alone configuration as normal, including trigger conditions, and save it to the data logger.
- Remove power from the data logger and deploy at your application’s location.
- Install the USB thumb drive into the data logger.
- Apply power.
Immediately, the device will go into Record mode or Armed mode (if you have trigger conditions setup).
This feature is available on all DI-2108, DI-2108-P, and DI-4000 products in stand-alone mode.
View Live Data (Ethernet Products Only)
Click on the View Live Data button in the WinDaq Dashboard utility to get a peek at your data as it streams to the removable USB flash drive.
![](https://www.dataq.com/blog/wp-content/uploads/2020/11/view-live-data.png)
Functions of the LiveViewer include Pause, Resume, Zoom In, Zoom Out, Waveform Up, Waveform Down, and Cursor Reading.
![](https://www.dataq.com/blog/wp-content/uploads/2020/11/live-viewer.png)
This feature is available on all DI-4000 Ethernet (DI-4108-E, DI-4208-E, DI-4718B-E) products in stand-alone mode. Specific Firmware and Hardware Revisions are Required.
Watch our YouTube video playlist for a full tutorial on Stand-alone setup and the LiveViewer utility.
![](https://www.dataq.com/blog/wp-content/uploads/2020/11/setup-videos-1.png)
Download the latest software at run.dataq.com.
Firmware and Hardware Revisions and Compatibility
Check to see if your device is compatible with each feature below:
Feature | Products | Hardware Rev | Firmware Rev |
Record on Power Startup | DI-2108, DI-2108-P, DI-4108, DI-4208 | P | 1.23 |
Record on Power Startup | DI-4718B | All | 1.23 |
LiveViewer | DI-4000 Series | All Ethernet | 1.23 |
If you have compatible hardware – read our knowledge base article How To Update Your DI-1100, DI-1110, DI-2108, DI-2108-P, DI-4108, DI-4208 or DI-4718B Firmware.
